F2 Tank on F3?
Old Feb 28, 2012 | 12:12 PM
Shiffts's Avatar
Default F2 Tank on F3?
As the title asks, will an F2 (1994) tank fit on an F3 (1996)? My F3 tank has a dent in the left side that irritates me whenever I see it.
They appear to be the same size..so it could be a direct bolt on?
Does the F2 accommodate for the F3 ram air intake? This is the critical deciding factor I feel.
Old Feb 28, 2012 | 05:48 PM
c_mo94's Avatar
the tanks themselves are identical.. its the petcocks that are different. im not exactly sure how to make the conversion. but the f2 has a vacuum hose, and the f3 is run off a fuel pump. hopefully someone else knows a little more about how to do the switch. good luck
Old Feb 28, 2012 | 06:02 PM
c_mo94's Avatar
Originally Posted by coalminer frank
The f2 petcock was vaccuum operated. Bike not running = petcock off. The f3 had a fuel pump so if the bike was off so was the pump. F3 petcock on the F2 = no fuel pump and no vaccuum so its gravity fed so in order to keep the fuel from flowing into the carbs just in case your carb floats are over whelmed from the gravity of a full tank the petcock needs to be shut off when the bike is shut off so the fuel will stop from flowing into the carbs and into the cylinders and flooding it out. Something like that.
here, this explains it a little better
Old Feb 29, 2012 | 03:05 AM
Shiffts's Avatar
So let me make sure I've got this right:
If I use an F2 tank & put my F3 petcock on there and keep the existing gas delivery setup of a the fuel pump, I should be ok and not have issues?
Or I could also use the F2 petcock along with the F2 tank without the fuel pump and run the fuel delivery system off a vacuum to the carbs?
If both are true, I think I'll put the F3 petcock on the F2 tank and use the fuel pump along with it.
Thanks for the help!
Old Feb 29, 2012 | 02:14 PM
Bill Fletcher's Avatar
the f3 will not stay running without the fuel pump (i have to buy a new one for my 95 project i just bought)... due to it having downdraft carbs (no float bowls) gravity feed is not enough to get the bike to do more than sputter and backfire like crazy
Old Jun 16, 2013 | 01:06 PM
jackojeff's Avatar
sorry but you are completely wrong the CBR 600 F3 95-98 use keihin cv carbs which will run off gravity feed as long as the differential pressure between your tank and your carbs is significant enough for the fuel to flow at a pressure constant enough to have a good supply of fuel, but better ran at high speed with something to keep pressure up such as a vacuum or fuel pump.
the f3 carbs DO have float bowls i should know iv stripped a few.
dsenk48
How-To: Mechanical
Sep 22, 2013 08:09 AM
SACBR
Jun 19, 2011 11:09 PM
jveach
Jun 12, 2011 12:45 PM
renns
Dec 14, 2006 01:14 AM
