Engine won't start after carbs cleaned
Old Sep 13, 2012 | 07:56 PM
koobs84's Avatar
Default Engine won't start after carbs cleaned
I just finished cleaning the carbs on my bike. I put everything back together and filled the tank with fresh gas. Engine cranks but will not start.
Pulled a plug and it appears to be working. Unscrewed the float bowl drain plug and gas was coming out so I know gas is getting to the carbs. I don't know what else would be the problem.
Old Sep 14, 2012 | 11:28 PM
Dirtrider009's Avatar
are the plugs wet or dry? if they are wet your not getting spark, so you might have jiggled one of the cables loose while messing with the carbs. Check your ground also. Try taking some ether and give her a shot or two see if itll fire.
Old Sep 15, 2012 | 11:53 PM
koobs84's Avatar
The plugs are actually dry. Which makes me believe the engine isn't getting enough fuel?? The battery is dead now after so many attempts so I'm gonna get it charged then check the coils in case one is bad.
Also could it possibly be the fuel pump?? I thought about checking it too and see if it's mechanically working.
Old Sep 19, 2012 | 10:06 PM
koobs84's Avatar
Charged the battery and everything works fine now!!
fatluke_nofx
May 3, 2012 07:03 AM
davidsass
Apr 15, 2011 12:54 AM
wish1267
Mar 28, 2010 10:50 PM
Juddelicious
May 10, 2008 11:41 PM
tds94probe
May 3, 2008 01:58 PM
