Chain & sprockets unsure
Hey thanks to the help of Dirt's write-ups and the rest of you guys
I have taken apart my f3 and replaced everything (maintenance wise).
But now I'm having a very hard time understanding and finding information
on what is a acceptable/safe chain&sprocket set up.
I have a 95 and from what I have read the oem is 15t main, 43t rear, and a 530 chain with 108 links.
I understand all that thankfully.
Now that I have gotten comfortable on my baby I want more low end, So my question is if I buy a 14t main, 45t rear (-1/+2) I guess you say?, and a 530 chain with 108 links is that an acceptable set-up, or will the chain now not be long enough?
Do I buy a longer chain but stay with 530, or change it up to 520 vise versa?
Very confused as you can see
For the -1/+2 change that you're proposing, You'll be fine with a 108 link chain.
You may lose a teeny bit of travel but it should fit fine.
The part about sprocket-chain size matching is correct. If you buy the
chain/sprockets as a kit, that's already dealt with. If you try to save a few bucks
with the build-your-own approach, you'll need to ensure size-compatability.
The conventional wisdom is to change chain and sprockets as a set. As they wear
they will 'seat' to each other. Using a newer chain and/or sprocket(s) together with
used parts, can add excess wear/stress to the ensemble.
Size considerations themselves, are a non-issue for the average rider. Stick to stock
chain size, unless you have a specific application (in which case, you already know
why you are changing).
Hope this helps, Ern
Think I figured it out,
according to JT's website these are the accurate parts applicable to a 95 F3
Can anyone confirm the set up will work?
D.I.D 530 Standard Series Chain - 108 Links,Chain Length: 108,Chain Type: 530 530 x 108 : Amazon.com : Automotive
