Engine help please!!!
Old Nov 19, 2016 | 08:18 PM
sportracer07's Avatar
Question Engine help please!!!
Hey guys i happened to come across a cbr 600 engine for free lol. Friend of mine cleaned out his garage and gave it to me. I know its from an f2 or f3 but not sure which, how can i determine what year the engine is or if its from an f2 or f3???
Old Nov 20, 2016 | 06:43 AM
coalminer frank's Avatar
The cam chain tensioner is longer on the F3 engine. Look at engines on ebay and compare.
Old Nov 20, 2016 | 07:35 PM
Thank you coalminer frank, looks like mine is an f2, are all the mounting points the same?
Old Nov 20, 2016 | 09:13 PM
Yes, all the mounting points are the same. Are the carbs on the engine? F3 carbs are 2mm bigger than F2 carbs plus the 36mm F3 carbs have a throttle position sensor on the left side of the carbs.
Old Dec 9, 2016 | 08:33 AM
marc0011's Avatar
Look at IDoDirt's post, there is an image listing things from 91 to 96. The engine number is stamped into the case and is located on the back side of the engine on top of the clutch housing.
https://cbrforum.com/forum/general-t...cbr600-129586/
Old Jan 15, 2017 | 01:53 PM
F2-streetfighter's Avatar
Default cbr600f2 clutch
hi I have just bought a 1994 cbr600f2.it did not start and was missing some parts like the clutch thrust washer and cone washer.now my clutch doesn't work.could this be because of the missing parts.
superlund
May 7, 2010 09:51 PM
SR20DETurbo
Jun 16, 2006 09:54 AM
suream
Jun 1, 2006 03:44 PM
