engine backfire
Old Jan 31, 2009 | 10:51 PM
robertjhunt's Avatar
Default engine backfire
I'm wanting to find out why it's backfiring when I let off the throttle. When I rev it up. I don't know if it's the carborator or it hasn't been re-jetted right or what. It has a D&D slip on exaust on it. I've checked the timing.
It's a '97 CBR 600 F3. Any ideas?
Old Jan 31, 2009 | 11:08 PM
f3BikeR's Avatar
A common sign that it's running lean. Any other symptoms that we can cue in on?
Old Feb 1, 2009 | 10:38 AM
I'll try that and see if it works. so i guess im adjusting the carbs today
I'll let you know how it goes. thanks for the help.
Old Feb 1, 2009 | 03:06 PM
pacemaker's Avatar
One of the most common causes of backfires is air getting into the exhaust system. This usually happens on the roll off (throttle off), cold air then gets sucked in from somewhere's.
Old Feb 1, 2009 | 03:20 PM
f3BikeR's Avatar
You should check out the service manual for proper adjustment of the pilot screws and will need the correct wrench to get to, and adjust them. The manual has the part #
tchyclutch7
Jun 26, 2012 01:59 PM
kinglee86
F2 Tech
Nov 15, 2010 01:42 PM
stealthcbr
Sep 13, 2005 01:08 AM
stealthcbr
Sep 8, 2005 02:56 PM
bluebowtie
May 4, 2005 07:39 PM
