Electrical problem
Old Sep 7, 2012 | 03:14 AM
15ura's Avatar
New Member
Default Electrical problem
hey guys i need help i got 96 honda cbr 600 f3 and its not charging the battery. i replaced the regulator twice and its keep burning it what can it be please help tell me what the problem if anybody know
Old Sep 7, 2012 | 06:30 AM
74demon's Avatar
There is more to the charging system than just the r/r. They are getting burned up for a reason. Perhaps a bad battery, shorted stator, or burned up connections. All of which are fairly common. Testing and checking them are simple with a DVOM and an open eye. Hatter should be along with links shortly, if you don't have a manual to guide you through the tests.
Old Sep 9, 2012 | 03:04 AM
jackojeff's Avatar
Cool This site has a search facility....USE IT
This has been posted by everyone including me about a bagillion times you could have done a search around!
Now il be nice after my rant
First check your battery voltage running
Second check it physically.
Third remove rr and scrub the earthing plate till its got a good finish, by that i mean for conductivity not so it looks nice and shiny.
Next check your stator i know ive 'burned' reg recs and turned out to be my stator had shorted out melted itself and that takes a lot of voltage.
You can remove your stator cover and inspect it if your mechanically minded but youll need a new gasket, make one out of a coco pops box that was a joke get genuine honda but they arent cheap. Or il be really nice and see if my haynes book of lies has a thing how to check sator?
Old Sep 9, 2012 | 05:07 AM
MadHattr059's Avatar
One of the common issues I've noted is the harness, itself, is under-wired for the
current it carries. i.e. it only uses about a 16-guage wire. If you have had to do
several replacements to the r/r and the stator checks out, run your own wiring
between the stator and the r/r (those 3 yellow wires). Use at least a 12-guage,
when you do this.
Here's my handy-dandy links to understand and diagnose most electrical/charging
issues on any bike...
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
Hope this helps, Ern
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
