Electrical charging system. HELP!
Old May 15, 2018 | 08:18 PM
98hondacbr600f3's Avatar
Default Electrical charging system. HELP!
Hey guys. I know this is a Harley page. But I'm in need of some help! I have a 98 Honda cbr600f3. Battery was dead. Changed it. Took her out, bike kept trying to die out in neutral and while holding the clutch. Had to roll stop signs to get home. It died in the driveway. Charged battery and it still tests fine. The old battery died because of running it on a bad charging system. Did some research. Tested my stator wire connections that come out of the case to the first plug. I read I should be reading 50-70volts. I was reading 15. Opened the case, stator had some clear discoloration on it. Put a brand new one in, still the same thing. Now with that being said, the stator obviously isn't putting out the power it should in order to charge the battery and run the bike. Would that mean it's the magneto not operating properly? I'm not sure where to look. I have no continuity to ground where I shouldn't. And I have it where I should. Kinda frustrated at this point. Any information helps!! Thanks guys
Old May 15, 2018 | 08:37 PM
74demon's Avatar
Harley page????
Check your regulator/rectifier and connections. They are a well documented failure point.
Old May 16, 2018 | 11:13 AM
Default Lol
I was on a harley electrical forum and just copied and pasted my post. Lol. Forgot to get rid of the harley part. Anyways. If the stator is brand new and not functioning properly. Shouldn't that mean that something ahead of the stator isn't working properly? I'd imagine so.
Old May 16, 2018 | 12:30 PM
74demon's Avatar
Did you check the R/R yet?
Old May 16, 2018 | 07:04 PM
So. I tested the stator connections after work. One leg reads just over 20, another reads just over 20 and the last one reads under 20. Dont know if this information helps in any way. I'm going to be testing the r/r and posting an update tomorrow.
Old Jun 3, 2018 | 09:16 PM
Shotgun Sherman's Avatar
Regulator/rectifier. Cheap enough to try for sure. I'm go in thru it now. Just snapped the clutch cable waiting for that to come in now. Then ill put them both on. Good luck. I hope I have good luck as well.
chrstphrmrrs
Mar 13, 2016 05:58 PM
93cbr1000f
Mar 18, 2009 10:25 AM
blaster
Nov 19, 2007 12:02 PM
