easy ground question?
Old 11-14-2013, 01:17 PM
this guy's Avatar
Default easy ground question?
Where dose the other end of the ground cable connect to?....I know one end is on the battery,but I forgot where the other end bolts to
Old 11-14-2013, 01:29 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
It gets bolted to the frame. Check somewhere for a common meeting point on the frame where several ground wires all come together. One of them should be the battery ground.
Old 11-14-2013, 01:45 PM
this guy's Avatar
Sorry I mean the main ground cable from the battery.. Looking for the stock location..I think its somewhere on the engine block?
Old 11-14-2013, 02:44 PM
RoadiJeff's Avatar
Like I said before, it gets bolted to the frame. I believe that's where mine is attached.
Old 11-14-2013, 05:23 PM
this guy's Avatar
Thanks roadijeff.Im just going to make a new location for the ground
Old 11-15-2013, 03:38 AM
jackojeff's Avatar
are you asking were the main earth wire earths out?
it attaches to the plate that your reg/rec also earths out but can go anywere that has good conductivity
Old 11-23-2013, 10:15 AM
Will.Bass's Avatar
mine bolts to the the top of the trans case. right in the middle behind the starter
Aheroicrevolt
05-08-2012 01:39 PM
Finch
10-20-2010 03:54 PM
Cytotek
08-24-2009 10:11 AM
chpsk8er630
05-16-2007 11:39 PM
FordFrenzy97
11-11-2005 01:52 PM
Quick Reply: easy ground question?
