95 600 f3 rich idle
Ok. Usually, the addition of a slip-on and a K&N would cause the bike to run slightly lean. So, I'm thinking a jet kit has also been added. In addition, the pilot jet adjustment has probably been richened up too much. Stock F3s are 1 1/2 turns out to start with and jet kits start around 2 turns out. Check by lightly screwing the adjustment screw under the floatbowl all the way in and count the number of turns. You might need a D shaped adjuster bit or make one with brass tubing. You can hope that the PO slotted the adj screws for a small screwdriver.
All four carbs need to be the same. Minor adjustments for each cylinder may be needed, but this should get you close.
thanks a bunch man. i wasnt sure how many turns i needed to start with on the pilot. since im not completely sure about the jet kit should i maybe go 1 3/4 out first and make minor adjustments or just go ahead with 2. Is there anyway to tell if the jets are bigger than stock? Would it be stamped on them? Is my picture still not showing up it wont be much help but i would like to know if i uploaded it correctly?
the pictures should be in the post work in progress by me. here is one just in case. its the entire bike cause i havent started working on it just yet. i have no garage to do it in and the rain is slowing down progress
Tweeek
10-23-2018 10:48 AM
