clip ons
Old May 9, 2008 | 12:08 PM
ominous1's Avatar
Default clip ons
ok I found out why my throtle was sticking right clipon is bent alittle .can u bend it back or is that going to compramise the strenght of it? I was told that honda used alot of interchangable clip ons which others would fit? cause oem price i might as well get a set of vortek's thanks
Old May 9, 2008 | 12:40 PM
redzintimidator's Avatar
Default RE: clip ons
Yea, you can bend it, but this type of aluminum is not very forgiving to bending. It usually just cracks n breaks. I would get a new one. Try ebay, i got one clip on for $15.
Old May 9, 2008 | 02:51 PM
KidCr3nshaw's Avatar
You can do the Vortex thing but you need to remember the bars are going to be smaller in diameter which means possibly new bar controls (turn signal perch, clutch perch, throttle tube, throttle/front brakeperch, etc.).
You can get all of that stuff aftermarket but some of it adds up quick. You can get controls and stuff all day long for cheap but usually aftermarket perchs' mean aftermarket levers - which can get pricey.
Good luck!
Old May 9, 2008 | 05:45 PM
ORIGINAL: KidCr3nshaw
Good luck!
good info!
So i guess this means you should probably stick to OEM.
Old May 9, 2008 | 06:12 PM
kwong2001's Avatar
Good luck!
Actually, the vortex clip-ons (and most aftermarket clip-ons for that matter) use the same diameter tubing as stock, so it'll bolt up just fine. The only thing you need to do is drill them for the switch housings. Unfortunately the newer vortex's don't work with our master cylinder, so he'd have to get something like a woodcraft.
Old May 9, 2008 | 10:36 PM
Yea ive heard something about the non-compatability of a supposidly compatable vortex clip on. ive just been staying away from them so i dont have to deal with it.
02 ratrider
Feb 6, 2013 11:00 PM
ominous1
Aug 23, 2008 08:20 PM
tank_900rr
Jul 14, 2007 07:34 PM
boats203steveb
Jun 24, 2007 01:41 PM
wheeler6747
Sep 9, 2006 09:16 PM
