Cleaned carbs now way too rich
RE: Cleaned carbs now way too rich
so i have my carbs open again and all my floats exposed. when you refer to a 'sticky' float, will it actually stick somewhere in it's range of movement? none of them do. i don't know exactly what i'm looking for :/ damn. any help? just found that my vacuum line between the top of carbs 2/3 was somehow jammed between the two fittings, so it was open. maybe this was my problem? i'm putting it all back together now to find out. also, I can't seem to get my butterflies to close 100%. they all remain open with maybe a 1mm gap. is this ok? they're all open the same amount and open/close in sync.
okay, just started it back up after finding the line to be incorrectly connected. now it runs much much much better, but it's still lagging when i try to drop revs. it still won't go up past about 7k rpm then it starts to sound like it's choking up a bit. are the butterflies supposed to close 100%?
