choke help
Old Jun 12, 2008 | 09:35 PM
huffx9's Avatar
Default choke help
got a 96 f3 and the choke has worked fine since ive had it, but the problem started maybe a day or 2 ago... i full choke it, try n start it and it turns over for maybe a second and dies. so i give it a little gas and that starts it up fine, but with the choke still at full it idles at like 500 rpm and dies, when it used to be like 3k+. so basically i used to start it up fine with the choke and let it warm up by itself, but now its come to me not even using choke and giving it gas for a couple mins to warm it up. any thoughts?
Old Jun 13, 2008 | 06:39 AM
Default RE: choke help
The end of thechoke cable sheething or housing is held in place by a single screw clamp thats attached to the carburetors. If the clamp came loose, the choke would not engage very well if at all. To get to that clamp you need to take the tank off, and the air cleaner housing. Disregard the red circle. My finger is touching the choke cable clamp.
Old Jun 13, 2008 | 07:22 AM
SilverF3's Avatar
or in front of the carbs there is two screws and springs that hold the choke braket in place mine was just really dirty and the screws got tighten or jamed up i took them off cleand so the whole bracket and choke system will work and put back together works just fine now.
Old Jun 14, 2008 | 12:27 AM
Sproutf3's Avatar
Registered Users
maybe you have a broken choke cable?
Old Jun 14, 2008 | 06:12 AM
I would think that if the choke cable had broken, then huffx9 would have noticed a difference in the way it feels when he engages it.
Old Jun 14, 2008 | 07:47 AM
redzintimidator's Avatar
Yea, it seems as though that clamp just loosened up a little bit. Just go in there n tighten 'er up and she should be good
Old Jun 14, 2008 | 09:33 AM
huffx9's Avatar
is it hard to take the tank off and watever else in order to get to the clamp?
Old Jun 15, 2008 | 07:03 PM
SilverF3's Avatar
Nope its easy an you got to take the air box off to
Old Jun 15, 2008 | 07:07 PM
The tank is easy to take off, just 2 bolts. There are 3 hoses that need to be disconnected. All are near the rear of the tank. 2 are just vent hoses, the other is attached to the fuel petcock. I would have a couple of short 2x4s around that you can set the tank on. If you set it directly on the ground, you will put weight on the petcock and possibly damage it. Once that is off, then a hand full of screws that remove the air cleaner cover and a few more to remove the air cleaner base. Once the base is off, you'll see the carburetors, throttle cable, and choke cable.
Old Jun 17, 2008 | 08:16 AM
neely321's Avatar
Well I took my tank off the other day to replaced my airfilter. I only had to hoses. The big one for the valve and the smallest one. What is the middle size one fore? I looked around bike bike and couldnt fine it so I guessed I didnt need it.
cuetip
Jul 28, 2012 03:56 PM
mbrown22
Nov 23, 2010 10:37 AM
dalves11
Sep 22, 2010 04:47 PM
pacemaker
Sep 26, 2009 11:32 AM
pointman
Mar 14, 2007 09:58 PM
