checked my compression
i also noticed when i took the plugs out that 2 of them were dry and clean and 2 of them were wet with dirty unburnt gas. i know i need to get my bike jetted but if i jet the carbs and only 2 of them are not burning all the gas what will this do? can i just adjust the carbs and get the 2 cylinders right?
after i clean them maybe ill put them back on and take them in to get sync'd. i have gotten mixed answers about jetting. i was told that any modification would require a jet kit. but i was also told to just put a stock air filter back in and that should solve the problem
it all started when i was taking it for its first ride on the highway and it stalled on me. it didn't kill the battery cause i could get it to crank it just wouldn't fire. i killed the battery trying to get it started again. got it home, jumped it and it fired. then i started to get brown smoke and the plugs had what looked to be oil on them. it was unburnt gas. so i got new plugs and wires. i also added a motorcycle carb cleaner to it and ran the tank of gas through. i am going to assume that is why i had white smoke out the back for a while. i am still getting unburnt gas in 2 of the cylinders and a little white smoke from time to time. but i still have some gas in it that was mixed with the carb cleaner. today i cleaned the garage and put the bike in there. i tore the top half apart so i could get at the carbs. the top half look clean but that doesn't mean much. i now have to figure out how to take the carbs off so that i can clean them. i have cleaned bike carbs many times on older bikes and harleys but never had to take them off an F3. this should be a fun time. got to get the tape out and mark everything soi know where it all goes when i put it back together.
