Charging issue....any tips?
Old 03-26-2010, 07:30 PM
ShadyOne13's Avatar
Default Charging issue....any tips?
So I JUST bought a 1997 F3 and I absolutely LOVE the bike. BUT. It is not charging correctly it seems....the previous owner put a new battery on the night I got it.
I have ridden a few hundred miles then blah, batt dead. I rolled it off to get home from work today and headlight stays bright for the whole 35 mile ride.
Get home and try and restart it and nothing. I am in the proccess of charging the battery now and will check voltage coming in tomm.
Is there anything I am unaware of I should check in the proccess?
Thanks in advance for any tips/help
Old 03-26-2010, 09:49 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
R/R could be out.
might wanna invest in a voltmeter (15.00) at walmart
and a motorcycle batt charger (20.00) at walmart.
Old 03-26-2010, 11:51 PM
The R/R is a known weak spot on Honda's. I suggest upgrading to a GSX/R regulator rectifier. They're easy to install, plenty of instructions on this forum, and they have much bigger heat sinks to dissipate all the heat.
Old 03-27-2010, 03:07 AM
joelacer's Avatar
Totally agree with IdoDirt. When I first got my F3 I was having issues with the R/R and battery too. I must have switched out R/R's and batteries like 3 times before I finally said to hell with this and bought a gsxr one. All I had to do was drill one hole and a little bit of basic soldering, and presto, charging problems solved. Been going for like 15k miles no with no issues.
Old 03-27-2010, 03:55 AM
yzf4i's Avatar
Could possibly be initial charge on a new battery. Bought a bike brand new from dealership and after 60 mi. or so the bike would run great but the battery didn't seem to get a charge. Problem: weak initial charge along with several short trips never allowed the battery to get fully charged. Threw it on a trickle charge for a day and haven't had a problem since!
Old 03-27-2010, 11:07 AM
ShadyOne13's Avatar
Well TY guys for the tips. I charged the bett pvernight and tested everything. I have 13.8 volts on cables with bike running and it not hooked up to batt.
R/R? rectifier? Sorry was not totally sure
Thanks again for the help
EDIT, nm I see it is rectifier. TY guys.
Old 03-27-2010, 01:19 PM
just make sure you get a harness too if your wires are out..
http://cgi.ebay.com/ebaymotors/CBR-H...s#ht_642wt_939
like 20 bucks tops on ebay (when mine went out, the wires melted)
it's good if you aren't a wire junkie like me
Old 03-27-2010, 04:44 PM
ShadyOne13's Avatar
well I snagged a rectifier for 50.00 shipped. My wiring is good still so we will see if it helps ty again
David Van Onselen
10-06-2013 02:03 PM
cklein85
05-26-2013 07:22 PM
Five
01-02-2009 09:44 AM
iconfever
06-03-2008 10:39 AM
maxima/nismo
08-18-2005 05:41 PM
Quick Reply: Charging issue....any tips?
