Charging issue
Old Dec 26, 2008 | 12:59 PM
Five's Avatar
Default Charging issue
It seems that my '87 isn't charging. I have the service manual and will do some testing but was wondering what would be the most likely culprit: Bad stator? Bad regulator/rectifier? Other?
Old Dec 26, 2008 | 01:18 PM
Hurricane rider's Avatar
Default RE: Charging issue
rectifier is the most likely culprit. take a look at it and see what it does.
Old Dec 26, 2008 | 01:35 PM
Five's Avatar
That's what I'll try first...thanks. I'll let you know.
Old Dec 27, 2008 | 03:39 AM
thegreenbandit's Avatar
id check the battery too
Old Dec 30, 2008 | 02:44 PM
rrasco's Avatar
ya, but the r/r is known for fudging up
check em both
Old Dec 30, 2008 | 07:52 PM
Five's Avatar
Picking up a parts bike tomorrow...should have both. I'm gonna test and swap as necessary.
Old Dec 31, 2008 | 12:28 AM
thrasher572's Avatar
Make sure you have a fully charged battery when you start testing. I will repeat myself again and again. The charging system is designed to keep a fully charged battery charged...not to refill an empty one. If you start with a dead battery you WILL damage your shiny new parts and have to start over.
I offer this advice with the experience of having ran a starter and alternator shop for three years with my father. The charging system failing is a SYMPTOM of a battery problem. Replace the battery or at least have it load tested to verify its condition.
Old Jan 2, 2009 | 09:44 AM
Saldo1981's Avatar
This is what happened to me. The battery was dead when I bought the bike. Jumped the bike off rode it home stuck it on a charger. Battery never charged, put a new battery in and it seems to be charging just fine now. Haven't rode it much since the rear wheel is way out of alignment and the chain is full of slack which I'll be taking care of soon..
David Van Onselen
Oct 6, 2013 02:03 PM
cklein85
May 26, 2013 07:22 PM
uptoodamlate
Nov 29, 2009 06:13 PM
ckxtreme
Jul 24, 2009 02:03 PM
iconfever
Jun 3, 2008 10:39 AM
