Changing rear shock using paddock stand
Old May 3, 2009 | 12:23 PM
m33ksy's Avatar
Default Changing rear shock using paddock stand
I'm looking at changing my rear shock as it's leaking and the rear is a little bouncy. However I don't have a garage so cant use straps to lift the bike. Is there anyway of changing the shock with just a rear paddock stand somehow? I understand the shock will still be under tension in this situation. Any advice will be greatly appreciated.
Old May 6, 2009 | 02:57 PM
Corvus's Avatar
I picked up this tip a while back, it works great!
Go out to your car and get the little bottle jack. Place it on top of your rear wheel, and brace it under the subframe/tail assembly. You might need to remove the plastic back there to prevent damage, or you can use a thin board inbetween to protect things. The tail is very light w/o you on it, so a couple of twists of the jack/tire will support the weight. You can then unbolt and remove the shock with ease!
Good luck!
Old May 7, 2009 | 03:36 AM
m33ksy's Avatar
Thanks very much for that Corvus I will give it a go sounds ideal.
Hudson
May 17, 2012 06:05 PM
birdstrike
Sep 24, 2007 12:20 PM
eye toke
Dec 30, 2006 01:35 PM
Krokus_92F2
May 29, 2006 02:51 PM
