chain tension question
Old Mar 9, 2017 | 02:21 PM
sonnyf3's Avatar
Default chain tension question
hello everyone!
i got a question regarding chain tension and adjusting, as my chain is lose as hell i thought ill give it ago and adjust it myself, so as i check the manual i saw that on the (page 75) u have imagine showing 2 nuts which has to be loosen up. (2) lock nut (3) drive chain adjustment nut. i found out i have only 1 nut on each side. is there something im missing?
motorcycle i have is 95' cbr600 f3
thank you for your help!
Old Mar 12, 2017 | 09:22 PM
sjona2011's Avatar
better to have your chain on the loose side. but yes, there should be two nuts on the adjuster, just run to a hardware store and grab a couple, probably 6mm nuts.
Old Mar 14, 2017 | 11:03 AM
sonnyf3's Avatar
all done! thank you
kash
May 29, 2006 05:50 AM
tweak mt
Mar 7, 2006 12:18 PM
clean929
Jun 21, 2005 12:24 PM
BlindLOKI
Mar 11, 2005 12:15 AM
BlindLOKI
Feb 18, 2005 11:48 PM
