CBR Carb Question
Was removing the carbs the other day for cleaning cause i have a bad issue with my 1996 CBR600f3 sputtering and busting out at higher rpms and when removing i notices 2 lines that were on the carbs when removed it looked as if it was antifreeze. Is this correct or is this a huge problem that ive ran into.
![Icon Playing](https://cbrforum.com/forum/images/smilies/icon_playing.gif)
yea i second that, unless the bike has been sitting for a really long time... or idk, if you really think its the carbs then clean them.
but the fuel pump could be the problem the bike will sputter and die and one time left me stranded an hour and a half from home. and i had to replace the pump a few weeks later. so you should check that out or bypass the pump and try riding the bike. hopefully you get it going...
