CBR 600 FV Earthing Points Locations
Hiya guys this is my first post and im hope you can help
i have a cbr600 fv:
I decided to get my frame blasted and painted coz of some rust areas
the frame looks arwsum now the only problem is that all the earthing points have been painted over and i cant remember where they all are, i have refitted the engine and the bikes not earthed properly and wont start, does anyone know the locations where it earths
any help would be arwsum cheers guys
Dom
i have a cbr600 fv:
Dom
there may have been one on the right side of the fairing stay, near where the fuses hooked up... i think i remember having a ground there. (screwed into the fairing stay)
It doesn't matter WHERE you're grounding (earthing), so long as it's to a bare metal part of the frame. It's all the same. Did you have the frame repainted? If you did, and you're attempting to ground by just flattening a wire under a screw, that won't work. Get some sandpaper, and scuff down the are where the wire will be grounded, to ensure metal-on-metal contact. If this is what you are doing, then it's not your problem, and you need to troubleshoot somewhere else.
