Carbs
Old May 16, 2011 | 05:45 PM
kerosene's Avatar
Ok, so new (used) set of carbs, same problem... carbs are overflowing from the T's, what the **** is going on?
Old May 16, 2011 | 09:24 PM
Post pictures of where it's coming from.
Old May 17, 2011 | 03:39 AM
SmokinJeff's Avatar
Did you replace the orings on the T's? It's not a bad idea with a questionable set of carbs to bench test them before installing. Save yourself some headache.
Oh, and a good source for O-rings is your local hydraulics shop.
Old May 17, 2011 | 07:45 AM
Mrmanr's Avatar
Check fuel hose that connects to T. Might have small hole or clamp not on right. I had same problem when I first did my carbs, it was just clamp. I always test my floats by lightly blowing through fuel line then doing same with carbs upside down to make sure needles close off all the way. Not compressed Air, just by mouth. Good luck !!!
Old May 17, 2011 | 08:32 AM
kerosene's Avatar
IDo, it's coming from the same T's that we were talking about before.
Old May 19, 2011 | 07:02 PM
kerosene's Avatar
so I got new o rings for 2 bucks for the gas T, going o test tomorrow
Spazbite
Sep 3, 2011 10:12 AM
vettefan
Dec 2, 2006 01:14 AM
vettefan
Dec 1, 2006 10:29 PM
yellow_900_rr
Aug 10, 2006 09:59 PM
