Carb Sync Help
Old Feb 18, 2012 | 05:18 PM
hss2010's Avatar
Default Carb Sync Help
98 F3. Not sure where to connect my sync tool. Anyone got some pictures or detailed directions to locate them?
Old Feb 18, 2012 | 08:37 PM
MadHattr059's Avatar
Just below the carbs, there are some little tubes with rubber caps on the headers.
That's where you hook up the guages. The #1 cylinder has a bolt INSTEAD of the
tube...What was Honda thinking!? You can get an extra port tube for about $5 at the dealership, it's the 5mm version.
Ern
Old Feb 19, 2012 | 08:05 AM
hss2010's Avatar
below the carbs meaning closer to the battery or straight down from like sky to ground? I have a tube so no worries on that. Also by tubes im assuming metal lines not rubber correct?
Old Feb 19, 2012 | 09:08 AM
Riza's Avatar
the carb synch lines go into little whole directly underneath each carb port (where the carberator connects to the engine).
Carb sync | Flickr - Photo Sharing!
The number 1 cylendar requires you screw an adapter into it before you can put a hose into it.
let me know if you still struggle and i can take some more pics.
Old Feb 19, 2012 | 10:44 AM
SpongeRR's Avatar
Here is another pic for you, showing all four connectors, simply pull off the rubber covers and then push the tubes for your balancer onto them, the No1 is a threaded one that screws in like Madhattr said.
I recommend a pair of very long nose pliers for getting to them, they are a royal pain in the ****! I bought some U.S. Tools pliers with 12" handles specificially for doing this job!
Old Feb 19, 2012 | 11:03 AM
hss2010's Avatar
thanks for that last pic. I took of my left side fairing and see the bolt for the #1 i think i see a rubber cap thing for #2. I can barely see #3 and 4 or feel them. theres a lot of hoses and other **** down there.
Old Feb 19, 2012 | 11:11 AM
SpongeRR's Avatar
Like i said, a set of very long nosed pliers will help no end, you sort of end up doing it blind!
Old Feb 19, 2012 | 01:30 PM
hss2010's Avatar
yea i didnt have that long of a pair but got in there fine with about an 8-10'' pair from handle to the tip of the needle nose.
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
scottiekarate17
Jul 24, 2011 03:47 PM
dakers0010
Sep 15, 2010 09:23 PM
camaropower
Mar 31, 2009 10:23 PM
chrisf
Aug 4, 2006 11:15 AM
