Carb removal
Old Aug 21, 2018 | 09:27 AM
ao917vu's Avatar
Default Carb removal
I'm sure this has been addressed numerous times....but I am new here and cannot find it. I have 1995 CBR-F3. It has been sitting for 4 years and needs a carb cleaning. I have watched numerous YouTube videos, read posts, and studied the repair manual. Here is where I am stuck. Everything has been straight forward up to the actual removal of the carbs.
On the LEFT side......I see and can get a screw driver on the band screws securing carbs to intake manifold. On the RIGHT side I cannot even see the screws....let alone get a screw driver on them. When loosening and re-tightening these screws.....is it done from the side(s) or from the front? Any tips would be greatly appreciated. Thank you.
Old Aug 21, 2018 | 09:36 AM
The screws on the right side are at the same, but opposite angle that the left side are positioned. If you don't have one, a really long screw driver will be needed. Not sure where you are located, but in the states Harbor Freight has set that are perfect for the job, and cheap. If they are the OEM, you can also get a socket on it, 8mm I think.
Old Aug 21, 2018 | 02:07 PM
ao917vu's Avatar
Thank you so much. That is critical info that I had not learned anywhere else. I got the screws loose....now struggling to get carbs off of the bike. Thanks again for your help.
Old Aug 21, 2018 | 05:23 PM
Grease Monkey's Avatar
New Member
Smile
Not long had the same problem, I found taking the upper engine mounting plates off gave a better view through to the securing clips. Be prepared for some heavy pulling if they're anything like mine , rubbers were that brittle they cracked ,but would also suggest lightly heating with a heat gun or hairdryer prior to removal & refitting to make a bit more plyable.🙂
Old Aug 21, 2018 | 08:10 PM
when trying to pull the carbs it's a pain because the rubber boots connecting them to the intake kind of weld themselves to the intake ports over the years. I have found hitting them really well with a hair dryer warms them up and softens them up and makes them somewhat pliable. You will still need to put forth a lot of effort to break the seal. But it can be done.
Old Aug 22, 2018 | 09:54 AM
ao917vu's Avatar
Thanks Grease monkey and hamlin6 !!! Great tip..... carbs are off. Glad I found this site and truly appreciate the help.
Old Aug 24, 2018 | 08:44 AM
EchoWars's Avatar
Just get a helper for the carb removal. One on each side with fingers interlocked underneath the carbs and pull (at the same angle as the rubber carb boots). It'll come right off.
Get some silicone grease (grease, not sealant) to smear on the boots for reinstall. I use Dow Corning High Vacuum Grease, but there are others that work well and are cheaper.
Hootie233
Jan 30, 2018 09:36 PM
dyracuse
Jan 17, 2010 07:59 PM
SERGIOC
Jun 22, 2007 06:05 PM
ciupe
Apr 22, 2006 02:23 AM
alm70
Mar 1, 2006 02:19 PM
