boot question
Old Feb 15, 2012 | 06:19 PM
patryk's Avatar
Default boot question
hi;
im new owner of 98 f3, and new member...
quick story short...i picked up 98 f3 as a project bike...
bike didnt start, i cleaned carbs new sparkplugs and battery ...yeay it started i run it for few minutes. being a project bike i didnt go faster then 20mph...then i put it on the stand went thru gears got it like to 50mph...my temp gage is broke and bike started to fill hot so i turn it off...
next day i did more troubleshooting and fan switch/groung is bad...no problem i bypassed it...then i tryied to srart buke again and no think...it turned but didnt start...i even used starter fluid..just flooded sparks plugs...dryed them put them back, recharged batt and tryied again ...nada... so i took cars out again and im in the middle of cleaning them...now my question...bike came with some spare parts...and 2 diffrent carb boots the one on the bike were short ones and beat up i also found secend set in the box ...maybe 1/4 or 1/6 inch taller and in better shape...
which boots are correct for f3... or any other sugestions how to get bike running...thanks
patryk
Old Feb 18, 2012 | 11:58 AM
Cr250r67's Avatar
If its the same as my 96 the boots should be about 24mm long.
Old Feb 19, 2012 | 07:19 AM
patryk's Avatar
Default 38mm?
i have another set of boots and i think they are 38mm 1.5 in what bike would they go to...?
Old Feb 19, 2012 | 09:27 AM
Riza's Avatar
the stock boots are 25 mm long and have an inner circumference of 40 mm on the end that connects to the engine.
Old Feb 19, 2012 | 12:47 PM
patryk's Avatar
so what would happen if i put 38 mm tall boots on?
Old Feb 19, 2012 | 03:25 PM
edwardzx7's Avatar
Tall ones are for your bike!!! Short ones came off of a f2. I just bought some short boots from a shop and was wondering the same thing a couple of weeks ago!
Old Feb 19, 2012 | 08:36 PM
patryk's Avatar
Thank you...try to put them on tommorow...any sugestions how to easy mount them ???
Old Feb 20, 2012 | 06:29 AM
Riza's Avatar
the 25mm ones i have are on an f3, i believe they are stock as well. not sure what using taller ones will do.
Ausher
Riding Gear
Jan 17, 2010 05:21 PM
bambam
Dec 7, 2009 10:22 AM
supersnake83
Jan 28, 2009 09:36 PM
MisterBasket
Riding Gear
Feb 25, 2007 07:26 PM
sbv32
Riding Gear
Mar 16, 2006 04:30 AM
