bike fell over, wont start unless in neutral
There is a little switch which is kinda embedded into the clutch perch. Make sure that it is opening and closing freely when you pull and release the clutch lever. If it doesn't look to be working correctly, you can check the switch by removing the lever from the perch. If you need to clean or lube the switch, it just pulls out from the perch (if I remember correctly). Inspect the switch and clean and lube as necessary. To make sure your work is done correctly, test it with an Ohm meter before installing.
Shoot, I know it's been like a year on this, but I was wondering if someone could help me out.. There is a little "switch" thing in there which is just no more than a connection; it has two little prongs on it and it goes into the housing. I was wondering exactly how that came out and if it could be pulled straight out and put into a new housing. Any advice on getting this bit out without causing damage to it would be awesome, thanks!
jdschmidt
06-07-2008 11:37 AM
