ECU fell out.pulled wires.got em' in.bike wont fire.now what?
Old Jun 3, 2008 | 01:28 PM
jdschmidt's Avatar
Default ECU fell out.pulled wires.got em' in.bike wont fire.now what?
Well when i was out riding the little computer box fell out. pulled all the wires out of the grey clip and was a mess..i got a wiring diagram and me n a buddy spent an hour or so making sur every thing was wired up right.. all looked good. this time when i turned the key the fuel pump did prime (it wouldnt before) and then i tried to start it. it sounded like it wanted to. but nothing. checked it again. and after a few days. still nothing. i checked the BAS fuse and all other fuses and they are perfect. could this have done something to the sensor up in the nose fairing? im about ready to take it to the stealership and let them fix it..but ill see if anyone here has some ideas first. thanks!
Old Jun 3, 2008 | 01:32 PM
Tahoe SC's Avatar
Default RE: ECU fell out. pulled wires. got em' in. bike wont fire. now what?
so the wires came out of the connectors with the pin and you put them back into the harness?
did you measure each wire from the harness side to make sure it truly is connected in the harness?
Old Jun 3, 2008 | 01:40 PM
jdschmidt's Avatar
yep..follwed the diagram around the bike 100% and everything seems to be connected. and in the right spot. went over it about 20 times.
Old Jun 3, 2008 | 01:57 PM
Tahoe SC's Avatar
did you drop the bike or anything like that after this happend?
if the fuel pump doesn't prime, the bike won't start.
you can try bypassing the bank angle sensor.
Old Jun 3, 2008 | 02:05 PM
whtan20's Avatar
When i lowsided hard, everything in my battery tray fell out (battery, ecu, seat, etc.) i put them back in and the bike fired up fine amazingly. What caused your bike to drop out the ecu?
Old Jun 3, 2008 | 02:06 PM
jdschmidt's Avatar
no, bike stayed up. the fuel pump does prime. but it didnt with the wires out(obviously)
i was hoping i wouldnt have to take off the front fairing..its a pain on my bike. oh well. worth a shot.
Old Jun 3, 2008 | 02:08 PM
jdschmidt's Avatar
ORIGINAL: whtan20
poor positioning on my part.. didn secure it down. was hitting the twisties. doing some wheelies on the straighs..probably moved it around to much and it just fell out. i hope i dont need a new computer.
Old Jun 3, 2008 | 02:24 PM
Todd84's Avatar
Are you getting spark? If you are getting fuel check to see if you are getting spark.
Old Jun 3, 2008 | 03:46 PM
Rennen's Avatar
check if the battery is putting out enough power.
Old Jun 3, 2008 | 04:39 PM
ampfp's Avatar
+1 battery must be dead. esp after a fall
