Bike doesnt run with choke off
I start my bike with the choke in the on position. After warming up and a few lite taps of the throttle it still idles around 2k and so I try to take the choke to the off position slowly a little at a time. Eventually not even halfway up it bogs and dies. If i ride it and turn it to the off position it bogs and die when I try to get on the throttle.
Im new to bikes and still learning. My buddy who worked on the bike before I bought it told me he did the tune up very recently. Any suggestions on what to check into? I have the fairings off for paint so checking things out wont be too hard. I searched before posting but couldnt match my problem. Thanks for the help.
you should not give it any gas, it should worm up by it self. once wormed up it should idel at around 3000 rpms, and yours is about 1000 off. on the left side of the bike right under the gas shot off valve there is a **** that you can turn. this **** will adjust your RPMs. when on choke and wormed up all the way it should jump to 3000, once the choke is off it should run at about 1200 rpms.
i hope this helps.
i hope this helps.
Then naturally, there is the possibility that your carburetors are dirty and in need of cleaning. If the bike sat over the winter with gas in it and wasn't properly "winterized", it's a probability.
Im going to check out more once I finish painting and takin pics. Thanks for the tips. My buddy did mess with that screw last time we checked the bike out so ima look into it again when he comes back around to put the wheels back on.
