Big question
Old Feb 21, 2009 | 10:34 PM
andyskate's Avatar
Default Big question
from 91 to 98 are the f2 and f3 compatible as far as fairing fitting goes..? Im thinker about buying a 97-98 honda cbr f3 fairing kit will it fit?
Old Feb 22, 2009 | 12:24 AM
phoenix239's Avatar
First question is what year bike are you trying to fit it on?
Ok, here goes... As far as I know the 95-96 front fairings and the 97-98 are the same, from what I've read the 91-94 will fit the 95-98, but don't work together as far as upper/lower goes.
The tail on the 91-94 is basically the same as the 95-96, the 97-98 will fit, but you need to change the taillight, taillight bracket and seat (seat will work, but there will be a gap).
Again this is all according to what I've read on the forums.
Old Feb 22, 2009 | 11:46 AM
andyskate's Avatar
ok so youre saying the tail section and headlight fairings are generally the same but the side fairngs arent basically..or are close. Ifr i buy the 97-98 f3 fairing kit i am going to be puting it on a 94 f2. does that help
Old Feb 22, 2009 | 07:35 PM
phoenix239's Avatar
It should work just fine, if worse comes to worse you may need to make mounts or adapters, but I don't think that is the case here.
What I was saying about the front is the upper from a 91-94 won't work with a 95-98 lower and vice versa, but if you have a upper and a lower in a kit it should fit on whatever year bike.
Old Feb 23, 2009 | 08:34 AM
Northernfirepower's Avatar
Your gonna need a newer seat, headlight, tailight. The headlight is at a diffrent angle.
Old Feb 23, 2009 | 08:50 AM
duplago's Avatar
Also need a windscreen and the f3 upper fairing stay. I put 98 f3 fairings on my 92 f2. I just changed the items already said and it looks 10x better. Def worth it. If you are patient on here or ebay a lot of the items can be found for a reasonable price. Plus selling your old parts offsets the cost.
Old Feb 23, 2009 | 09:04 AM
I know someone that needs some F2 fairings so if yours are in good shape, I may have a buyer lined up for some of it already.
Old Feb 23, 2009 | 05:41 PM
andyskate's Avatar
I have the upper fairing piece and the right tail fairing
Old Feb 24, 2009 | 08:19 AM
I'll let her know
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
