best way to by pass the kickstand killswitch
Old Aug 9, 2013 | 05:00 PM
lovinsF3's Avatar
Default best way to by pass the kickstand killswitch
so I hear you just can wire the green wire and the green and white wire together is it that easy pictures and examples would be great
Old Aug 9, 2013 | 06:33 PM
Harmless's Avatar
I just got a paper clip and bent it into the connection under the tank
Old Aug 9, 2013 | 08:37 PM
Will.Bass's Avatar
no pictures necessary...very straight forward. take the seat and tank off. on the forward side of the battery box, there are 4 or 5 electrical plugs. the connector you want is green. it is a 3 pin connector. one side the wire is green, the other green/white and the middle will be yellow/black..just undo a paper clip so its straight, and then bend so it can be stuck in the back of the plug touching the wires you need..
Old Aug 10, 2013 | 01:59 PM
derekvercher's Avatar
Why would you want to bypass it? Could save your azz
Old Aug 10, 2013 | 05:00 PM
Will.Bass's Avatar
i was wondering the exact same thing, but then realized he open another thread for the same problem..i guess hoping to get more hits..
Old Aug 11, 2013 | 07:37 PM
Hondacbr600's Avatar
Just zip tie the sensor to the position that's needed for the light to be off.. There is a tab and mine broke so this is what I had to do.. Even tho I'd rather have the kickstand switch working
Old Aug 12, 2013 | 09:41 AM
jackojeff's Avatar
my sidestand switch was faulty so i needed it bypassing also race bikes need it bypassing as it wont turn on with the switch disconnected
two outer wires soldered to each other and boom a way better idea than a paper clip or zip tie and takes max 30 minutes and gets rid of an extra wire
Old Aug 12, 2013 | 10:58 PM
lovinsF3's Avatar
well with my very limited mechanical skills it seems cheaper and easyer to just bypass the perso wh owned it had the it taped up underneath the seat
Old Aug 18, 2013 | 07:39 AM
MadHattr059's Avatar
If you're on the street, best to replace/repair.
Pogo-ing the bike on a left turn can be really expensive/dangerous.
Cost is minimal, time is the same as bypassing it.
There is a reason why all bikes come equipped with them.
Ern
Old Aug 19, 2013 | 10:41 AM
jackojeff's Avatar
Ern
or just get into the habit of taping the kick stand with your heal before setting off
no kill switch = less to go wrong
