Battery not getting a charge
A couple days ago my bike just stopped running and had no power to turn over, we jumped the bike and it started but once i put it in gear it died again and had no power. When i got it home i trickel charged it and everything worked fine. the weekend before this my battery was dead do to my kids playing with it. I jumped it and took it for a 10mile ride and i didn't even have a charge when i got home so i charged it up and it work good til i broke down. May i add that my son also decided he would wash the bike, and by wash i mean soak it down good, he also filled my tail pipe with water, but back to the battery problems, does anyone know why it's not getting a charge, could the flood job my son did short something out, and is there anyway i could test it to make sure thats the right part so i'm not just getting random parts and hoping that it will be fixed
thanks
thanks
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
This will get you started. Check the connector, looking for heat signs (melted/warped plastic, burnt pins). If you see that or the epoxy-fill on the r/r is, itself, cracked/not smooth probably the r/r.
You can go with a used 90's GXR 900ish series r/r or for a new replacement, either the Honda upgrade replacement or (my personal choice) www.electrosport.com
Ern
Ern
Originally Posted by MadHattr059;1105240
You can go with a used 90's GXR 900ish series r/r or for a [U
new[/U] replacement, either the Honda upgrade replacement or (my personal choice) www.electrosport.com
Ern
Ern
The gsxr one is solid.
Make sure you solder the wires, or look into a way of making a connector.
5 wires: +,-, and 3 (ususally yellow) are stator wires.
Easy fix for beginners.
forgot to mention it cost me about 50 bucks.
keep an eye out, i have seen them go for 9.99 free shipping.
