air pressure
Old Apr 26, 2005 | 07:55 PM
grwilson6's Avatar
Default air pressure
hey ive lost my manual and was wonderin if anyone can tell me the recommended air pressure for my 96 f3. thanks
Old Apr 27, 2005 | 02:02 AM
sirlimpzalot's Avatar
Default RE: air pressure
Most bikes respond well on the street with a minimum of at least 32 PSI front and I usually run 34-36PSI in the rear..the tire sidewall will show 41 PSI but that makes the tire very stiff
On hte track it is quite a bit different and you can ask someone that has been to that track what they run or know
Old Apr 28, 2005 | 03:15 AM
grwilson6's Avatar
thanks man
Old May 15, 2005 | 09:57 PM
guycali's Avatar
Manual says 36 front and 42 rear.
Old May 17, 2005 | 03:48 PM
the 36 front might be acceptable but the rear at 42 is WAY to much...good for mileage but not good for adhesion unless you are really heavy and/or riding two up. I stick to the pressures I stated before.
motosikel
Oct 23, 2008 10:12 PM
motosikel
Oct 15, 2008 12:06 PM
Shortysboy09
May 7, 2007 05:04 PM
t_t2
Nov 15, 2006 08:28 AM
the_newt
Nov 4, 2006 05:07 PM
