Is aftermarket clutch cover gasket safe?
Old Oct 15, 2016 | 01:43 PM
kuad's Avatar
Default Is aftermarket clutch cover gasket safe?
I am trying to find a gasket to replace clutch cover and all I seem to find is aftermarket. Are these safe?
Clutch Cover Gasket $5.71
http://www.ebay.com/itm/HONDA-95-98-...IAzpcg&vxp=mtr
Grateful,
Dennis
Old Oct 16, 2016 | 06:32 AM
coalminer frank's Avatar
I dont see why it wouldnt. Look through the manual and see if it recommends a very very light coat of gasket adhesive on either or both sides of the gasket.
Old Oct 16, 2016 | 06:41 AM
kuad's Avatar
Coalminer frank,
Thank you for the reply!
Old Oct 16, 2016 | 07:34 AM
Conrice's Avatar
Indian Head engine shellac both sides of it - it won't leak!
Old Oct 18, 2016 | 04:49 PM
sjona2011's Avatar
This^^^
that gasket will work. but its really a one time use unless you take the cover of within a few days, and why buy a new gasket every time you take your clutch cover off when you can just use some rtv on it.
Old Oct 20, 2016 | 10:22 AM
kuad's Avatar
Thanks everyone!
Old Oct 20, 2016 | 11:13 AM
Jaybird180's Avatar
Originally Posted by sjona2011
This^^^
Unless you're racing, how often does a clutch cover need to come off?
Old Oct 21, 2016 | 01:19 PM
kuad's Avatar
When the clutch cover has corrosion it needs to come off.
Old Oct 21, 2016 | 08:19 PM
sjona2011's Avatar
just depends, theyre old bikes, if the clutch/springs go out, if youve got a bent shift fork or worn out shift drum the covers would need to come off.
but no matter what, id rather spend $5 on a tube of rtv that'll seal the cover 100 times over, than to spend $10 any time i take the cover off.
siCk f 4 i
F4i - Wanted
Jul 25, 2011 04:26 AM
Avi
Mar 21, 2011 01:11 PM
estate4life
Jan 15, 2009 11:59 PM
klutch_r
Jan 6, 2008 10:31 PM
