98 CBR F3 Questions from a new rider
Old Oct 15, 2011 | 05:48 PM
Originally Posted by Wildcat86
I took it to another shop here in town, and aside from him telling me "if I were you, I'd part it out", told me the oil splatter pattern looked weird, because its also coming from in front of the oil pan. He told me to degrease it/clean it and see where its coming from.
Don't part it out, that would be stupid. I do agree with getting it cleaned up. Start with some Simple Green that you can get at Home Depot and clean all the oil and grease off everywhere you can see.
I took off the sprocket cover, and the inside is covered with oil on the bottom, so I'm pretty sure I've got where my oil leak is.
So how would I go about taking off the sprocket to replace the seal? Which section of the factory manual do I look at? 7: Engine Installation?
You guys are life savers.
Once it's cleaned up, you can make a judgment on what needs to be done next. You can remove the front sprocket easily enough. Make sure you leave the rear wheel on the bike and the chain installed while trying to get the bolt off that holds the front sprocket on. You can put a 2x4 through the spokes of the rear wheel while getting the bolt loose on the front sprocket. It's a standard "righty tighty, lefty loosy" bolt on that sprocket. Once you have the bolt off, you can then remove the rear wheel and there is plenty of slack in the chain to be able to get the front sprocket off without having to break it.
Oh yea, I forgot to mention. I couldn't find anywhere in the manual that talks about that seal. I guess you'll have to get it cleaned up and the sprocket removed before you can determine what the cause is. After it's clean, but before you take it apart, take it for a ride so you can attempt to see if oil is leaking somewhere. I hope it's not that the PO just used motor oil to lubricate the chain and that's the mess it caused.
Let us know how it goes. Those are great photo's BTW, so keep'em coming.
FoxMillCrew
Riding Gear
Jul 10, 2007 05:02 PM
camoweasel
Jul 4, 2007 11:47 AM
cjlerra
May 14, 2007 12:01 PM
kausi
Dec 11, 2005 02:03 AM
GetYourGreens
Oct 4, 2005 01:13 PM
