97 f3 idle charging???
hello to all
i did a search but found nothing
has any body figuired out how to get these cbr f3 to charge in the 13.00+volts range at idle mine at 1200rpm shows 12.65 then after rev 3000rpm or over it starts going up then if i hold the revs 4000rpm it reads 14.70 volts
Most motorcycles won't charge the battery while idling. The F3's are no exception. Charging voltage is attained by having the engine RPM's around 3000-4000. If you let your bike idle long enough, you may have difficulty getting it started again. It's easy enough to get it charged again, just go for a ride for about 10 minutes and you're good to go again. What you're seeing is normal.
While the bike is operating, the R/R needs to be putting out a voltage of at least 13.5 to be able to run all the electrical components and still have enough left over to charge the battery, and should at no time exceed 14.8, or the battery will fry. At idle, the R/R may put out as little as a flat 12v, which would run the bike, but not charge anything.
http://www.offwidth.co.uk/bike/gener...lt_finding.pdf
Please post what readings you get at 2.5k and 5k.
WhiteHawk
04-02-2009 02:00 PM
