95 f3 sputtering
Old Jan 30, 2012 | 01:03 AM
The Grinch CBR 600 F3's Avatar
Default 95 f3 sputtering
back in October I was riding my bike daily with no issues. Earlier I had a stator and rectifier go out and I replaced them in early September. My bike ran great until I found my bike sputtering when I was cruising down the interstate at about 60 mph and I got off the exit and check it out. It would idle fine I could rev it to red line no problem. But when I put it in gear and go through 1st gear to 8K rpm I shift to second and when I hit about 4k rpm it sputters. I have replaced the spark plugs, replaced my fuel line. I haven't checked my carbs and I'm looking at the fuel filter tomorrow. Any ideas before I take my carbs to the shop.
Old Jan 30, 2012 | 08:25 AM
hss2010's Avatar
dont believe the 95 had the ram air setup. So thats out. Only thing I can think of is with your carbs. A leak at the boot, jet(s) dirty, other adjustments.
Old Jan 30, 2012 | 03:53 PM
bkubes's Avatar
maybe try bypassing the low-speed intake?
https://cbrforum.com/forum/cbr-600f3...83/#post840830
Mine was hooked up correctly, but missing pieces .. I decided to bypass it and have had no problems.
I had a fuse blow on me while I was cruising ~60, and it also happened to control the air solenoid. Same symptoms you're describing.
Old Jan 31, 2012 | 08:49 AM
Thank a lot I didn't think of the airflow ill check em out
murderedoutf3
May 6, 2009 07:17 PM
89cane
Feb 6, 2009 04:43 AM
fbristow
Sep 3, 2008 09:39 PM
rtd2005
Apr 26, 2007 10:18 PM
rtd2005
Mar 13, 2007 03:54 AM
