95 cbr600 f3 gauges aren’t working
Old Jul 9, 2018 | 12:54 PM
Bdepalo's Avatar
Default 95 cbr600 f3 gauges aren’t working
I was recently changing out my headlight to an led and accidently touched two wires together and heard a pop. Now non of my gauges work on my dash but blinkers and taillight work fine. Also the bike starts up and idles perfect/revs up perfect no problem but when riding in gear It bogs down randomly and have to play with the throttle to get going again. This all happened right after that pop noise from the headlight wires touching. I’ve replaced the fuel pump, checked all of the fuses in he fuse box, replaced the voltage regulator and the ICM. Is there some sort of relay somewhere that probably crapped out when I shorted out the wires?? So frustrating! Please help!
Old Jul 9, 2018 | 07:37 PM
Rkarr's Avatar
Disconnect battery before MX
Old Jul 17, 2018 | 03:03 PM
IB Cheryl's Avatar
IB Staff
Hi, I moved your thread to the CBR600 F3 forum. Hopefully you'll get your question answered there.
Thanks
Old Jul 23, 2018 | 03:56 AM
gamekiller7's Avatar
Have you checked the fuses?
Old Jul 28, 2018 | 01:34 AM
edwardzx7's Avatar
He said fuses were checked above.......... I would disconnect the battery and light. Run a positive and negative from the battery to the light just to make sure your bulb isn’t blown. If everything else was checked.
madalive8
Mar 30, 2011 10:51 PM
extreamtacoma
Feb 21, 2010 01:10 AM
tomvoy
May 6, 2009 11:36 AM
OLDBIKE
Mar 15, 2007 10:56 AM
05Repsol1000rr
May 1, 2006 01:22 AM
