95 CBR600 F3 Brakes grab
Old Jan 22, 2011 | 10:51 PM
RobRz's Avatar
Smile 95 CBR600 F3 Brakes grab
Hi all
Just bought myself a 95 F3 and I seem to have a front brake problem,
when I pull up to a stop everything is fine but as it slows down to about a walking pace the brakes start to grab, I'm not sure what it is because you can't feel any pulsing on the lever and the pads have lots of meat left on them, I did notice the brake fluid is bright green like radiator fluid? has anyone ever seen brake fluid that colour?
any opinions would be appreciated!!!!
Cheers
Rob
Old Jan 23, 2011 | 03:35 AM
edwardzx7's Avatar
Wassup bro, Drain the green stuff and put new brake fluid in there and bleed your brake system.More than likely your system has air in it.But i would deff get rid of the green stuff! pictures of the green stuff would be nice.
Old Jan 23, 2011 | 10:56 PM
RobRz's Avatar
G'day Ed
I changed the fluid and took it for a test ride and it was going good but then it started pissing down rain so didn't get to heat em up,
here is a pic anyway (it may not work, I'm a noob)
Old Jan 26, 2011 | 08:07 PM
F3LUV's Avatar
agree with all of the above ^.... i had this problem and it almost put me face down in the rode during a stoppie. i got all the old fluid out and did a full bleed and everything is cured
Old Jan 26, 2011 | 10:08 PM
RobRz's Avatar
I'm still getting the grabbing, anyone think its possible that the pads are really old and gone bad?
Old Jan 27, 2011 | 01:46 AM
Craig84's Avatar
you know i have kinda the same problem, they just seem to grab occasionally. But with mine its nothing to bad you can hear it when i walk the bike back, its a little screeching noise. now is there something specially different from bleeding brakes on a car to a bike? Cause I know how to do it on a car and i cant see it being much different but im just curious?
Old Jan 27, 2011 | 03:53 AM
RobRz's Avatar
mine doesn't screech and it only does in when riding and not all the time, other than that they work fine.
the bleeding in simple and same as on a car, on the F3 you have to do the right one first (from a sitting on the bike postion).
full procedure is here https://cbrforum.com/forum/stickies-91/brake-bleeding-fluid-change-600f2-f3-models-110088/
Old Jan 28, 2011 | 09:55 AM
edwardzx7's Avatar
Check your rotors! maybe they are warped(don't know just a guess).Change rotors and pads.You might need a new caliper.?Just throwing some things out there,but i would check the main stuff.
Old Jan 29, 2011 | 03:54 AM
RobRz's Avatar
Smile
I don't think it's the rotors for 2 reasons, 1 you can't feel it in the lever? and 2 it doesn't always do it, in fact since changing the fluid like you suggested it is doing it alot less and seems to be getting better the more I ride it, I took it up to my local hot spot and flogged the hell out of it on the week end and that seemed to have helped.
I have now decided it's something I can live with so long as the condition is improving.
Thanks for your help mate, did you check out the pic of that green fluid?
Rob
10Drunks&ADriver
Oct 17, 2010 01:24 PM
Sweeper1
May 10, 2009 04:35 PM
jonathanfunderberg
Jun 28, 2008 05:01 AM
alexr40
Sep 19, 2006 04:55 PM
