95 cbr 600, clutch issues
Old Oct 9, 2021 | 06:52 PM
StephenD's Avatar
Default 95 cbr 600, clutch issues
Hi I got a 95 cbr awhile back had to replace the clutch, feels like the clutch is starting to slip again and may need to replace🤦‍♂️ and has been a month or less since the new one was put in. idk if I’m riding the bike too hard or incorrectly letting clutch out to fast dropping it too much or engine braking too much, also feels like the bike overheats sometime idk if it’s out of coolant and am gonna check it when it cools down, I just don’t know what would make the plates ware down so quickly, it is also my daily drive and I ride hard and fast all the time lol🤷‍♂️
Old Oct 10, 2021 | 12:36 AM
If it really is the clutch worn out, I'd say it was not adjusted properly. If there was no slack in the clutch cable, then the clutch may not have been fully engaged. This would cause premature failure/wear.
Old Oct 10, 2021 | 10:04 AM
StephenD's Avatar
how would it be adjusted properly at the plates in the basket and hub or by the cable? The bike is at high Rpm and it’s not catching like it should thing is normally a rocket, same thing happened before and changed plates and went back to normal for a month.
Old Oct 10, 2021 | 10:22 AM
The clutch lever should have between 10 - 20 mm of free play as measured at the end of the clutch lever. That free play ensures that there is no tension on the clutch cable which would prevent the clutch from fully engaging.
Old Oct 10, 2021 | 11:30 AM
StephenD's Avatar
so it should feel loose mine feels kind of tight🤷‍♂️
Old Oct 10, 2021 | 11:31 AM
StephenD's Avatar
also thank you💯
Arsi
May 27, 2012 06:21 AM
Cinderfella
Aug 9, 2010 08:59 AM
DunnRR
May 19, 2010 11:25 PM
86vdubb
Aug 10, 2008 09:57 PM
rallye
Jun 19, 2008 11:34 AM
