3rd/4th gear engine bog
Old Mar 27, 2013 | 05:27 PM
Bradi007's Avatar
New Member
Question 3rd/4th gear engine bog
Hi, I am new to this site and curious if anybody can give me some advice on where to go next. I got a 95 f3 I acquired on the cheap. In the process of putting on f4i/600rr fairs and tail, didn't come with any fairings...
Now to the point, bike sat for years, prolly 3 to 5 at least. Pulled the tank and flushed it, pulled the Carb/bowls/jets and throughly cleaned. Put a new fuel pump/ filter. Spark plugs. Checked any fuel/vacume lines/ Carb boots. I have checked or replaced pretty much every thing I can think of. The bike starts great, revs great, I get on it and it rips thru first gear and second but when I hit third or forth it like it running outta gas or the bowls are empty. If I let off for a sec and get back on it, it will rip for a sec then cut out....
Any help will be much appreciated!
Old Apr 1, 2013 | 07:30 AM
Bradi007's Avatar
New Member
Anybody????
Old Apr 2, 2013 | 12:03 PM
alienjoe's Avatar
Check your float settings. Maybe they are too high and shutting off? Really sounds like a fuel pump issue though. As the bike needs more fuel with a higher load, if the pump isn't supplying it, it will do what you said. Be careful though, a lean bike blows engines
Old Apr 2, 2013 | 01:37 PM
Bradi007's Avatar
New Member
I thought the same alienjoe. I checked them twice. And like I said anything and everything to do with fuel, spark.. I have been reading about this air solinode thing and would have never thought that it can play that much of a role being the f3's are ram air. Soo I have my fingers crossed that's it. Hopefully get a chance to look at it within the next week or so, been working crazy hours!
Thank you for the reply and any other idears you might have I am deff open o suggestions!!!
jwind
Jul 14, 2015 10:18 PM
freakyb
Sep 19, 2009 10:14 AM
xxlostrealmxx
Jul 24, 2009 03:16 PM
KD-05cbr
Jun 16, 2009 01:06 AM
wheeler6747
Mar 24, 2008 11:28 AM
