180 rear tire... can i fit 190
Old Jul 2, 2006 | 03:05 PM
mattleo's Avatar
Default 180 rear tire... can i fit 190
i have a 180 and i need a new tire. can i fit a 190 i know it slows turning down but i like the look of the wider tire in the rear. does any one have a 190 and will it fit.. i am tight with a 180 but can it fit.. or how can i accomplish this thank you
Old Jul 4, 2006 | 01:49 AM
transamlt1man's Avatar
Default RE: 180 rear tire... can i fit 190
You don't have a liter bike so you don't need a 190.
Old Jul 5, 2006 | 02:56 AM
mattleo's Avatar
thanx i know u are die hard for stock everything but like i said in the original post i like the look of the fatter tire. so i will ask my question again i am not looking for your opinion on it. i am looking for a answer. because i dont know. thank you
Old Jul 5, 2006 | 10:48 AM
gerharddvs's Avatar
Hi, my 95’ F3 came out with a 160 at the back. I see you have a 180. Is it possible to fit a 180 without having to widen the rim or lift the mudguard and is it safe? Cause around here the 180s go for much cheaper then the 160s
Old Jul 5, 2006 | 11:06 AM
zach538467's Avatar
If you guys go to the search and type in tire size, this topic has already been beaten to death...
Old Jul 5, 2006 | 11:30 AM
Nick I.'s Avatar
read this article before you go dicking around with larger tire sizes.
http://www.sportrider.com/tech/tires...ize/index.html
Old Jul 5, 2006 | 08:52 PM
nunya95's Avatar
i had one on my 1995 f3 i liked it on there but its not much wider then the 180 because the rim is only 5 inches wide so it wont get no wider it took bends the same as the 160 and 180 so its up to you if u put one on
CBRbanas
May 4, 2012 01:39 PM
jcowick
Mar 8, 2007 01:22 AM
Kearnsy
Feb 8, 2007 01:42 PM
