Wont start
Old Jan 18, 2006 | 02:11 AM
chadderkdawg's Avatar
Default Wont start
I have a 93 600 F2 and i bought it a few months ago and got a good 2 months use out of it. I went to start it and it turns over but it just wont fire, it will backfire every once and a while but thats about it. Any ideas? Checked the timing and its good, cams arent broken either. Thanks guys.
Old Jan 18, 2006 | 05:31 AM
pupdog_88's Avatar
Default RE: Wont start
change the plugs sounds like you fouled them.
Old Jan 18, 2006 | 06:24 PM
joranb's Avatar
ORIGINAL: chadderkdawg
how long has it sat between the last time it started? Its possible you could need new plugs. They are pretty cheap( between $5 and $7)and easy to install. Try that. also make sure your battery is fully charged. If it still doesnt start it could be your carbs need cleaning. these are just suggestions that may or may not solve your problem. Im no certified mechanic, im just trying to help out a fellow rider with the little knowledge I do have. Hope it helps.
Old Jan 19, 2006 | 04:49 PM
Its been a while since it ran, pry 2 or 3 months, my dad seems to think the timing is off, he said he checked one plug because he didnt want to have to go through the hassle of getting at the other ones. Im in college right now so i took the bike home and told dad he could fiddle with it. Ill check the plugs when i go home this weekend, if that isnt it then im taking it into the shop.
Old Jan 19, 2006 | 08:32 PM
joranb's Avatar
If it was running fine before you left it sitting then make sure battery is fully charged. Also check all of the plugs or just change them all. This way you can rule this out and you will only benefit from it. good luck.
Old Jan 19, 2006 | 09:38 PM
transamlt1man's Avatar
I am 100% sure u have a fouled plug. Replace them all and go ride. Then come back and tell me I'm right I've had that problem along with a lot of others.
Old Jan 20, 2006 | 11:46 PM
dc_220's Avatar
I agree, sounds exactly like the problem I had with my f2, especially the backfiring
Old Jan 23, 2006 | 09:31 PM
Thanks guys, i will definately give that a shot, thanks for the help! Next project is the Accord that is running on 3 cylinders, grrrrrreat. [:@]
Old Jan 28, 2006 | 07:24 AM
dc_220's Avatar
with the accord, check your distributor, make sure it doesn't have a lot of carbon build up, just pull the cap and you can see easily, if that's not it, check to see if the 4th is firing and the plug. If not you need new wires. If it goes beyond that you need your motor rebuilt, because you are not getting any compression to that cylinder. Let me know if any of that helps.
It could be just a loose plug wire too.
Old Feb 1, 2006 | 12:49 AM
Yea there was just a cracked pug wire that was sparking into the block, no big. Thanks though, still havent gotten the cbr running, i pulled the plugs and they really dont look too bad but looks can be decieving, i still gotta buy some new plugs and try them out though. Thanks for the help guys, ill lecha know how it goes.
supermover25
Mar 15, 2019 08:14 PM
C Jacob W
Jul 29, 2013 11:03 AM
CTcbr929
Jul 31, 2009 12:25 PM
tagger609
Jun 27, 2008 02:09 PM
mishab
Sep 7, 2007 01:00 AM
