Won’t go in gear
Old Aug 4, 2020 | 03:58 PM
Phil314's Avatar
Ok, I just looked over the wiring schematic.
Kickstand switch has 3 wires - Dark green, Yellow/black, Green/white.
When the Dark green & Yellow/black pair are connected (kickstand down), it turns on the kickstand dash light.
When the Dark green & Green/white pair are connected (kickstand up), it tells the ignition module 'kickstand is up' or 'Run in gear'.
So if there's a problem Dark green & Green/white wires or that connection in the kickstand switch
you could get a kickstand dash light that works, but a bike that won't run when in gear.
You need to check both sides (up and down continuity) of the kickstand switch.
And also trace the Green/white wire for breaks/shorts.
Old Aug 5, 2020 | 02:40 PM
Christo Christo's Avatar
It’s the neutral light that stays on Phil am rubbish with electrics is that connected to kickstand?
Old Aug 6, 2020 | 12:03 PM
I read your reply again Phil on My lunch break and I think I understand what Your saying I never read Your reply properly Am going to have look at weekend and take few pics Thanks for Your help Phil
Shaun Stringfellow
May 5, 2020 02:30 AM
roketfreek
May 31, 2011 02:50 PM
badpie426
Oct 24, 2010 09:08 PM
Jin
Jul 20, 2008 07:20 PM
P954
May 30, 2007 12:41 AM
