wheelies?
wheelies?
I am trying to get the hang of wheelies on my 91 f2 but i just cant get the front up that far. my friend that has had a 96 fzr for 2-3 years can do them like cake on the f2 he says sit down ones are started at 6k rpm. can anyone help me try to learn i dont want to pop the clutch either b.c i need a new sproket kit
RE: wheelies?
A bigger sprocket? well, I've been doing wheelies on my f2 and found that the best way to wheelie is to clutch it in first! go about 5-10 mph then rev it then release the clutch but keep your throttle hand steady. You'll notice you will get the front up about a few inches then as you start to get use to it, rev it up a lil higher... so on so on... but make sure you take it easy. It takes time! Good luck
RE: wheelies?
when you are at about 5g or so pull the throttle back, when it starts to feel squirly quickly let off and pull back. you can't really go by a spec. rpm...that's what i was trying to do to start, but not all bikes are the same and the weight difference between riders makes quite a difference too.
helpful video
helpful video
