What is this piece called?
Old 10-12-2012, 10:05 AM
g32bturbo's Avatar
Default What is this piece called?
And do I need it? I have one on the other side. One day I was doing routine maintenance and discovered it was missing... The piece that goes on the end of the swingarm.
Old 10-12-2012, 10:12 AM
g32bturbo's Avatar
ok, found my own answer. It's called.....a plate! Do I need it right this minute?\
oh by the way, if anyone ever needs parts..
http://www.hondafrontline.com/fiche_...93&fveh=124843
these guys are right down the street from me.
Old 10-12-2012, 10:19 AM
adrenalnjunky's Avatar
What's missing is the end plate, and the 2 adjusting nuts for your your chain tensioner system there.
you definitely need it to properly align your rear axle and tension your chain if you ever loosen your rear axle. You don't have to have it to ride if the axle is tight and everything is in line. You could get by with a big washer, and replacing the missing nuts if you needed to line stuff up right now.
I'd definitely make sure the rear axle is properly tight, just to be safe.
replacement part is like $12-ish. You need PArts # 11, 24, & 25 on this diagram.
Hammond Indiana, Honda, Yamaha, Kawasaki, Suzuki, Sea-Doo, Can-Am, Polaris, Ski, Tucker Rocky, Parts, ATV, Motorcycle, UTV, Accessories, Apparel,
Old 10-12-2012, 10:21 AM
the reason for the 2 nuts, is to that you can tighten them against each other once you have everything lined up and the rear axle tightened. Once the rear axle is tight, nothing can slide forward or back. If those 2 nuts aren't tight against each other, and against the plate, they'll vibrate right off.
Old 10-12-2012, 10:25 AM
g32bturbo's Avatar
thank you for the quick response! i'm in the middle of deciding if its time to put the bike up for winter so I'll probably get it next week before I forget.
BlackBy4
08-15-2012 09:52 PM
mike7466
06-13-2010 07:09 AM
Bracey0self
12-07-2007 02:33 PM
Quick Reply: What is this piece called?
