what doesit look like?
No, he means the birdcage/fairing stay... the metal bracket that holds the gauges and the mirror mounts and the headlight.
there are two rubber grommets on the fairing stay that the two plastic thingys (light grey triangle) on the headlight fit in. kinda like the way the rear fairing has rubber grommets that you push the plastic (triangle/pyramid locater things) into.
(sorry, that is probably hard to understand )
edit: here is a pic where you can see the mounting
