very hard initial start...
Old Nov 4, 2007 | 09:30 PM
Stunda's Avatar
Default very hard initial start...
i dropped a new engine in my bike about 3 or so weeks ago, it has 7,000 miles on it and runs strong. Yet the first start-up is rediculously hard. i have to have the choke off and pump the throttle vigorously while turning it over. Sometimes it takes 25-30 seconds to slowly begin to fire up. But after it has started once, i can stop and start it no problem at all. any ideas? thanks in advance
Old Nov 4, 2007 | 09:43 PM
Sand.Man's Avatar
Default RE: very hard initial start...
plugged fuel filters?
Old Nov 5, 2007 | 06:33 AM
woo545's Avatar
ORIGINAL: Hershey
Wouldn't plugged fuel filters show signs of issues while running? I would think there would already be gas in the carbs from the last time it was running. I'm asking because I don't know. I'm having a very similiar issue when trying to start my F2 when it is cold.
Old Nov 5, 2007 | 02:15 PM
Sand.Man's Avatar
It's gotta be something to do with fuel delivery, could be many things though... carbs would be what I would check first but I cant give youa definitive answer[&:]
Old Nov 5, 2007 | 03:07 PM
CBR13F2's Avatar
i would go with plugged pilot jets. i believe the pilot controls fuel from start up to about 4Krpms then the main kicks in. they may not be open all the way.
Old Nov 5, 2007 | 06:35 PM
woo545's Avatar
I read somewhere that if the a bike doesn't start when it's cold then it's an ignition issue and not a fuel delivery issue. Don't know if that's true or not.
Old Nov 5, 2007 | 07:07 PM
bergs's Avatar
Pilot jet is used for about about 1500 RPM's (call it 1/8 to 1/4 turn of thegrip) then you're on the main jet.
I'd check the choke cable tension to make sure the choke isn't already partially open when the lever's closed, check and/or replace plug boots/ wires if cracked, check and/or replace the plugs, definitelybalance the carbs. If not any of that, I'd be looking into tearing the carbs apart...
FWIW, my '03 FZ1 has done the very same thing since I bought it...hard starting when stone cold but fine after some warm up...even after a pipe and jets.
Old Nov 6, 2007 | 01:43 PM
Stunda's Avatar
i dont believe its a carb related problem because i used the carbs from my old engine and i never had any problem with it. It may be the plugs, as i didnt swap my olds ones into this engine, i just used the ones already in it...
Old Nov 6, 2007 | 01:47 PM
Sand.Man's Avatar
Mmm... straight swap with carbs will require some tweaking, every engine runs differently.
Do you know the jet sizes from your carbs? you got any aftermarket bits like K&N or exhaust?
Did you adjust the pilot settings?
Old Nov 7, 2007 | 11:48 AM
kjohnson's Avatar
Always pull the plugs and go from there.
Alexanderfitu
Feb 25, 2014 07:15 AM
hmm
Jun 13, 2013 12:03 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
railcrzy
Mar 25, 2010 03:58 PM
JayBoCC2
Jun 23, 2009 10:23 PM
