Using motorcycle jack
Old Apr 24, 2009 | 10:20 PM
Ralph's Avatar
Default Using motorcycle jack
Hey all, please forgive me if this should go in the newbie section. What is the best way to lift the F2? Looks to me like the exhaust is in the way. Does this need to be removed?
Thanks for your understanding and advise.
Ralph
Old Apr 24, 2009 | 11:08 PM
Sand.Man's Avatar
I've never used a "lift" style jack like you probably have, Most commonly used for sportbikes are front and rear stands.
Those jacks are mostly for dirtbikes and 1800lb cruisers where the frame rails are the lowest point on the bike.
Because the frame does not loop around the motor, and the oil pan is the lowest spot you could jack from, I don't know if I would use a bike jack on it... The fins on the oil pan are not very strong so be cautious if you are brave enough to lift it from the oil pan.
Old Apr 25, 2009 | 11:26 AM
CaliKush's Avatar
yeah i suggest to just use the bike stand..
omninate
Feb 14, 2009 08:34 AM
riegnman
Jul 10, 2008 09:50 AM
44Gilly
Feb 20, 2007 02:18 PM
Zhenya13
Jun 25, 2006 07:08 PM
OldFatGuy
Dec 20, 2005 09:27 PM
