Turn Signals and Guages not working
Hello Everyone, Im hopeing someone can help me, about two weeks ago I installed flush mount turn signals on my 94 f2, everything was working fine, about four days later i noticed the signal indicator gauge on the cluster was blinking faster, then the next day all of a sudden I went to put on my signal and NOTHING, the turn signal guages on the cluster doesnt come on and the rear signals dont come on. However when I switch the turn signal switch to the right, the right front turn signal goes off and when I switch it to the left, the left signal goes off. Now these turn signals are the running lights also, so they are always on. ALso keep in mind the back signals dont come on at all. This is very strange and just and fyi, I check the fuses they are fine and i checked the wiring to the back signals that i installed and everything is hooked up rite. Keep in mind i didnt do any changing to the front turn signals, only the back. Please help.lol
I have the same problem, I just put new bulbs in so I know it's not that. I think it is the flasher relay, I just ordered a new one so I'll let you know when it gets here. But you should check your handlebar switch in the meantime. It's a easy check if you have a multimeter.
Thanks sparky, I have changed the bulbs and checked the wiring and nothing...Are you have the exact same problem or is yours just blinking fast. I was thinking about the switch but it has to be working if when i slide it, it turns the signal off.....????
