Turn signal issue
None of my turn signals work, rears are brand new, bulbs good, front bulbs are new and good. if I hit the switch to turn, the front light on that side will go out and no blinking occurs. (2 filament bulbs) rears do nothing..
I hear no clicking or anything either. Fuse appears fine.
Switch or relay?
Switch or relay?
Possibly a relay issue.
but - you should not have dual filament rear bulbs - the rear lights on motorcycles are usually turn only, they don't light up all the time like the fronts so they only need one filament. Possible if you've put a dual filament bulb in, something is messing with the circuit.
Were they working fine until you made some recent change?
I'd take all 4 bulbs out, and start testing one socket at a time to see what happens.
