throttle handle sticks
#21
Protip - Use hairspray - once the alcohol evaporates the sticky left behind keeps everything locked down, without the mess of dealing with the grip glue that is recommended.
#22
I used to use hairspray on my mountain bike grips but there is a problem with getting even just a little water through them. When the grip starts to slip from the ends, it's only a matter of time before the grip can be easily slid off of the bar.
I have since used rubbing alcohol. The wetness allows you to slide the grip and position it and when it dries, there is no residue that becomes slippery with moisture.
#23
Yeah - works great as well, I used to wrench on bicycles in college, Aqua-Net was our secret weapon, but the alcohol was great too.
with lock-on grips now, there's no need of anything - I'm kinda surprised the idea/technology hasn't moved over to motorcycles yet. Would make grip swaps so simple, and I would assume would open the door for more color customization and stuff since the process would be completed with nothing more than an allenwrench.
#24
yes actually it did and it dried up really fast as well and they dont move even at high speeds.. i put just enough on the inside to lube it on to the bar the excess i poured out of the grip so it didnt slip right off.. but yea it worked.. relatively well might i add.
