Throttle Cable Slack
Old Aug 1, 2009 | 12:05 PM
GetOuttaMyWay's Avatar
Default Throttle Cable Slack
Can someone explain to me how to adjust the throttle cable slack? I just got the bike recently and there's too much slack on the cable, makes it a little difficult to learn smooth throttle control.
Thanks!
Old Aug 1, 2009 | 02:09 PM
Sand.Man's Avatar
The adjustment is on the carburetors where the cables are attached.
There are 2 nuts per cable, an adjuster and a lock nut. The end of the cable housing is threaded, so that as you back the cable away from the adjusting nut it will take out slack.
There should be some play in the cable, just enough to keep the throttle from being held on.
It's not the easiest thing to explain without drawing up diagrams, but once you pull the gas tank and airbox off and see where the cables attach it will make sense to you.
Old Aug 1, 2009 | 02:11 PM
Oh, so I do have to pull the gas tank off, that's helpful to know. So I've never pulled the gas tank off. I'm guessing I have to drain the tank first? whats the best way to do that?
thanks again.
Old Aug 1, 2009 | 02:14 PM
Sand.Man's Avatar
No, just turn off the fuel valve.
To remove the tank you'll need to remove the tail plastics and your seat. The tank is held on by 2 bolts, one at the front and one at the rear of the tank.
Be sure to turn the petcock to OFF, and remove the hoses that are attached on the underside of the tank. DO NOT forget to put the hoses back on (there are 2 of them) where they came off.
Many people forget to attach the small vacuum line back to the petcock and the bike will not run.
There are 2 vent hoses attached to the tank that just hang down and do not attach to anything else, you can leave those hoses attached to the tank.
Old Aug 1, 2009 | 02:28 PM
Beautiful. You just demystified my motorcycle for me. Thanks!
Old Aug 4, 2009 | 09:19 PM
Polonius's Avatar
Wait! Before you take that tank off! Put a rag under the big supply hose when you pull it off the petcock. The gas in the hose will drain onto it and be soaked up. It's not a lot, but it'll make a mess anyway.
Old Aug 4, 2009 | 10:53 PM
Sand.Man's Avatar
Fuel evaporates, let er' drip lol.
Optimus_Prime
F2 Tech
Jul 29, 2011 01:01 AM
cbr6rider
Apr 20, 2011 08:57 AM
dis3as3d
Aug 15, 2007 03:13 PM
all8280bcc
Jan 9, 2007 02:02 PM
angryscientist
Sep 29, 2006 07:51 PM
